Results 1 to 3 of 3
Thread: Clutch pedal snapped/stuck to floor
    Was leaving work for the day on Thurs and when depressing the clutch, it went back with a snap/crunch and was stuck to the floor.
    I couldn't see the damage apart from a plastic clip that fell to the floor in two pieces.
    Got it towed to my usual place, and they looked at it on the Friday and said that there were around 9 pieces that needed replacing including the master cylinder, and that it'd cost $650 but i'd need to wait till Monday for the parts.
    Just got called up Moday and they discovered the pedal itself had snapped so they'd need to wait another day for another $90 part to come in. I said that sounded more like what i'd read, that it was normally a cheap fix, but they reckoned that the master cylinder failed which sized up and caused the clutch pedal to snap.
    Does $740 seem a bit excessive for this fix?
    Pedal failed on my S3. I had it apart before the towie arrived. Using just a leatherman. A dude in the next street welded it for me. All back together under an hour from breaking it. On a Sunday.
    If they aren't a vw specialist I could see it running up a lot.
    Jul 2007
    Brissy
    I only needed mine welded, no extra parts. I did have it towed however.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
