Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: cluster swap?
  1. #21
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by Back Door Shenanigans. View Post
    Im confused here. What are the two sets of clusters in the first couple of posts? If you go from no MFA to one with MFA you will need the stalk to control the MFA. I can try and dig something up on that but the first post you had has it well defined. You may have an issue here if you have the immo defeat and may need your old ecu. I can't confirm that but i have heard cases of that causing an issue. Basically you will need to put the old ecu in swap clusters then the other ecu can go back in. This is all if its immo3.
    My bad here - the clocks shown in the photos are GTI and Bora Sport which both have half FIS. I was remembering Anthony's original 1.6 clocks which have no display - ie. just as my 2.0 clocks have no display. I'd assume that Anthony will be swapping the stalk from the GTI to control the Bora Sport clocks ...
  2. #22
    Nov 2006
    Largs Bay, S.A.
    This video might be useful re. key adaption
    https://www.youtube.com/watch?v=Wj3K04eMV7w
