Results 1 to 10 of 11
Thread: Clunking in rear after lowering on KWs
    Jun 2009
    Melbourne, VIC
    After installing my KWs and removing the rear perches for more lows there's been a metal clunking sound in the back when going over bumps. I jacked it up and everything feels tight except for the spring which can twist around when the car is all the way up.. could that be it? It only seems to come from the right side though which is weird.
    VW Bora V6 4motion
    Aug 2009
    ACT
    On my mk3 my rear beam hits my exhaust.. Could that be it?
    Point Cook, Vic
    When the suspension is at full droop are the springs still 100% captive? If not it could cause you grief
    Also check the bolts at the top mount. If they are a little loose you can experience clunking.
    FOLLOW US ON FACEBOOK
    bushes to your rear beam? the rear beam actually hitting the chassis or something?
    Aug 2009
    I had this. Albeit 2wd and it was the bolt under the perch (unless they're completely removed not just the adjuster?) on the drivers side.
    I tighten them and no more rattle.
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Quote Originally Posted by audi-tone View Post
    thats a good point. have you removed just the adjuster or the whole perch? if the whole perch make sure the spring actually sits in the bottom mount nicely when compressed under the weight of the car
    Jul 2010
    qld
    After lowering my a3 the exhaust pipe hits the axle
    Might be the case?
    Radiators are over rated
    Jun 2009
    Melbourne, VIC
    Thanks for the insight guys.
    When at full droop the spring can't fall out although it can twist around.
    I removed the adjuster AND the perch.
    I'll jack it up on the weekend and take a look at the rear beam, exhaust, etc.. Thing with the exhaust is that the muffler is on the left side (don't know how the whole exhaust snakes around though?) but I can only hear the sound from the right side..
    VW Bora V6 4motion
    Jul 2007
    Brissy
    Quote Originally Posted by jpflorez View Post
    Drivers seat makes everything sound like its on the right side. Get someone else to drive and sit in the passenger seat, see if it is louder on the left.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by JustCruisn View Post
    When my wife drives I try and listen real hard for the sound but can barely hear it on the passenger side..
    VW Bora V6 4motion
