Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Clunking on Deceleration
    Sep 2009
    brisbane
    Quote Originally Posted by caputo9 View Post
    Yeah i need to run them justcruzn as my wheels rub the front coils, plus it looks better when the wheels fill out the guards properly.
    Dylan when you say right hardware you mean bolt size?
    Im using stock bolts with them because i wouldve thought they'd be fine. the guy i purchased off of, ran them for a while without any problems on stock bolts. so maybe i just didnt tighten them up properly when i first put them on? but it was only the front left that was loose, every other wheel was tight
    You need longer bolts if they are slip on spacers. Ie if they are 5mm spacers, you need bolts with 5mm more thread. Stock bolts are 27mm of thread iirc
    Thread length, seat type, hub centric spacers? All will cause issues if not correct
    Jan 2014
    Adelaide, East Side
    They're 25mm bolt on hubcentric spacers and from knowledge of the friend i bought them off, the stock bolt length is correct. the seat type is correct, and the only conclusion i can come to is that they weren't tight enough on the car
    __________________________________________________ ______
    MK4 GTI - Reflex Silver - <<<Click for Build!<<<
    -Previously Owned a MK4 1.6L Golf - Reflex Silver
