A few options. Most of them you can find here. I've got the FK ones at the moment and they're not too bad
ECS tuning
Another option is to grab a set of glass headlight covers.
Hi all,
I've spent a good 2hrs unsuccessfully trying to restore my very clouded headlights, I've hit it three times with a variety of sandpapers (from 400 to 3000grit) and obviously headlight cleaning fluids/compounds and the cloudiness is still mostly there. The kit made very little difference.
The next stage will be to rip out the rotary buffer, but I'm wondering if I'm not better off doing an upgrade instead of spending the money on new rotary pads and cutting compounds?
What sort of aftermarket options are there? I wouldn't mind upgrading the headlights if I can for a reasonable price. Not wanting HID's for legal reasons but is there lights that look better than the standard fog light version headlights?
Where can I get them from?
Appreciate any advice on this conundrum.
Cheers,
RubAVeeDubDub
Originally Posted by MightyCarMods
-| "Laura" - 2001 Bora 4-motion (now sold) |-
ECS tuning
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
Just be aware that US Spec headlights dip the opposite way to what we use here, which is not only a safety issue, but also a compliance issue. If you install US headlights you'll be blinding oncoming drivers, even when you are using low beam as the low beam will point to the right, not the left.
[EDIT] just read that some of the aftermarket lights come with a switch, which will change the projection from LHD to RHD! BDS - do the lights you got from ECS come with the switch?
[EDIT EDIT] I now I see that ECS are actually stocking Euro Spec lights now! This is great, because they never used to when I was last looking
2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
MY15 Golf Wagon Comfortline
I emailed ECS a week or so and supposedly they do not offer any RHD headlights for us - maybe I got the wrong info though?
Perhaps someone could email them to see if Euro spec means RHD, just to see if a different answer is given?
Can confirm the fk ones switch left to right
The euro oem ones from ecs are still ldh I believe. It's just the way the light spreads rather then the cut off angle gravey mentioned
Hey mate, which FK ones did you get?
Just confused as I've asked both FK and ECS about their RHD headlight options...
Response I got from FK:
And the response I got from ECS...This light is LHD only not for your roads....
This is all we have for your car in RHD:
http://www.carparts-tuning.co.uk/Lighting-Tuning/Headlight-RHD/?filterKategoriePfadROOT=Lighting+Tuning&filterKat egoriePfadROOT%2FLighting+Tuning=Headlight+RHD&fil terVehicle+Model=Bora&filterVehicle+Manufacturer=V W&verbose=true&catalog=true&searchparam=%2A
Mit freundlichen Grüssen / Best Regards / Très cordialement
David Howe | Export Department
As for the headlights we only carry LHD drive lights and to my knowledge none of them can switch to RHD.
Tuning FK Automotive | headlight Angel Eyes VW Bora Typ 1J Yr. 98-04 black | purchase online
These. Tricky simon also had a set and had no problems switching them to rhd.
I never ran mine on the road, but beam pattern looked ok for us on my garage wall.
There was a dirty big metal lever inside you had to lick into lhd or rhd before fitting
Thanks for all the help guys - seriously!
I've given up on restoring these headlights (tried to hand buff them today with no real results) so I'm looking at trying to locate a 2nd hand set in Oz, buying headlight covers or an aftermarket set of headlights.
If I was to buy a 2nd hand set, which bora models came with fog lights? This is probably my least favourite option because they'll likely be at least half hazed at best.
The whole RHD vs LHD issue is not something I even considered so thanks for the heads up on that folks.
If I was to buy new headlight covers, I assume I'm going to have the same problems?
Glad to hear from first hand experience with aftermarket headlights.
With shipping, a set of those FKs equate to about $200AUS.
More than I was hoping to rectify this issue, but I suppose I'll end up with a new headlight.
I'm assuming the headlights would NOT be ADR approved though?
Are the 'Angel eyes' basically parkers or are they like a DRL function?
Dylan - do you know how Simon wired these in? On a separate switch or how a set of DRL's are meant to be by ADR laws - i.e. DRL turn off when the beams are turned on.
Sorry for all the questions!
Appreciate any help on this.
They are the parkers unfortunately. Ruins the look of one of the only ok looking after market set
