Results 1 to 7 of 7
Thread: Clearance on mk4 golf
    Oct 2011
    Wodonga Victoria
    17/7.5 et 32 with 225/45/17 tyres and if lowered with 30mm eibach springs will tyres clear guard?
    yes will be fine, tyres will be no where near the guards.
    VWW Official MKIV Wheel Q&A
    While I believe this is more then 30mm springs. will give you an idea on how they will sit
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Albury, NSW Australia
    18x8 ET32 225/40. You'll have 6.5mm more clearance on the inside and outside than above.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Quote Originally Posted by YellowDieselGolf View Post
    what suspension you have in at the time of these photos?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    KW V3. I don't know how low it's sitting in the pic, but I keep it set fairly high.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Feb 2007
    Hi Paul,
    I currently have 17x8 +32 with 215/45 and they clear the guards. The wheel setup you've mentioned is narrower but retains the same offset which should see you with around 6mm less poke, and 6mm greater clearance toward the strut (according to the Offset Calculator. The tyres you've mentioned are of course wider, but only by 10mm.
    I'm not sure how much a 30mm drop is compared to my current height, but I've had my wheel + tyres on standard 4x4-height suspension and lowered and it's been fine in both instances - the setup actually fits better the lower I went.
    -Matt.
    Mk3.Mk4.Mk1
    My Mk1 Project
    Oct 2011
    Wodonga Victoria
    Quote Originally Posted by madglf3 View Post
    Hi Paul,
    -Matt.
    Thanks Matt, yeah going to be a bit of trial and error, so I'll see how I go
