Results 1 to 10 of 15
Thread: temp rising, temp sensor or themostat
    Aug 2007
    doncaster, vic
    temp rising - temp sensor or thermostat??
    hi guys, car is stating to over heat, the water pump was replaced 40,000kms ago.
    its not over heating fully like it did when it was the waterpump, it will slowly increase 2-3 bars above the norm.
    with the radiator one hose is cool one is hot.. so there doesnt seem to be a blockage.
    on the freeway the car still overheats at speed.
    what do you think?
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    The fuse hasn't melted on top of the battery has it that controls the thermo fans? Do they come on when it's overheating?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Aug 2007
    doncaster, vic
    yeh fans are working they seem to be working overtime, doesn't seem to be coming on at the right time though ...
    May 2007
    PM Jimmymac, he might be able to help you...
    Aug 2007
    Im afraid that does still sound like the impellar is spinning on your water pump. Try this start your engine , now you will need both hands - with your right squeeze the top rad hose and at the same time rev the engine with your left and you should feel pressure in the hose as the pump is forcing the coolant round the system - should feel like it wants to swell. If nothing then the problem lies in the water pump for sure. If it turns out to be the pump replace it with one with a metal impellar. Mate if it swells then we will look at something else , now the fact that it is doing it at speed tells me its not thermo fan related as such more engine as you should be getting good air flow to the rad.
    Jmac
    Alba European
    Aug 2007
    doncaster, vic
    thanks jmac... ill see what happens tonight... it better not be the waterpump!
    what do the metallic waterpumps cost?
    Aug 2007
    Mate you will pay Around $95 at Vw for the bakalite one and you will find you will pay around the same for the metal one. I just did a metal one for around the $95 mark, I trust you did your Timing belt and stuff then??? If not now will be the time.
    CHeers
    Alba European
    Aug 2007
    doncaster, vic
    boys ended up being the thermostat $55
    Aug 2007
    Stuck closed hey - little bugger ah well not as bad as a pump - take it the pressure test was good pressure - thats good news mate.
    Jmac
    Alba European
    Aug 2007
    doncaster, vic
    yeh thanks for you help man!!
