ok since then i've had it looked at reasonably thoroughly, replaced diverter valve, replaced the N75 (J type), new sparkies, cleaned throttle body, new coolant temp sensor cos old one was apparently faulty, and the time is still:
post-service: 8.0 sec
so it didn't improve it the slightest bit!
this is really sh**ting me big time. what the hell is going on???
If it's of any use, the unitronic program is supposed to run the car at a nominal 16psi.
Reading off my crappy NewSouth guage, in 1st it gets to 10psi, in 2nd it gets to 15psi, and in 5th it actually gets up to 18psi and sometimes a little more!
Just so much about my car is shi77ing me right now. For one the installation of the boost guage seems to have stuffed up the Dim circuit on my dash, the new single mass flywheel n clutch seems to chatter when it starts to engage under 2000rpm which is moderately annoying... We took the hard donbone bushes out and returned to stock cos it was terrible IMO.
the boost guage needle vibrates at max boost which is an easy fix but i havn't got round to it yet...
my gearbox is di*ky and rough between gears and sometimes even at the lights if physically won't go into first...
i just want someone to steal the car so i can start over!
I'm gonna get it inspected on a dyno to see if that will help shine some light on the matter...
anyone reading this?
