if your car is chipped I'd recommend NGK BKR7E or PFR7B (platinum plug version). I've got the PFR7B ready 2 be installed at my next service.
Hi people.I know this has been covered but just after some real time advice on plugs for my 1.8t.
Had Revo stage 1 for a couple of months.Checked my stock bosch (3 prongs) plugs and they could probably do with a change.Are the NGK plugs as good as the vw / audi branded bosch plugs in the car at the moment and if so do I go the BKUR6ET or the one step colder BKUR7ET.Car has revo ecu flash but no other mods.Also are the NGK 3 pronged and does it make any difference to standard plugs.Do the NGK need to be gapped and how many miles can I expect out of them.
Any advice or experiences greatly appreciated
Trent
MK4 GTI Revo Stage 1 / BFI Dogbone Mounts / 710N DV
1999 Golf GTi - SOLD
2005 Golf GTI (2 Door) - SOLD
2014 Octavia RS400 Combi
1997 Golf GTI (Daily/Track Hack)
cheers Fiz
I too would recommend the bkr7e's I have them in my chipped gti (gapped at 28 thou) and love them, they don't last very long however (circa 15000 kms) but at $5 each and a 20 minute install job I don't mind.
hey lito do you need to gap them yourself or do they come as 0.28
I'm running BKUR6ET's atm as recommended by NGK. Runs perfect, but I'd like to try the colder 7 as alot of yanks recommend. Same revo tune.
2001 MkIV GTIRevo Stg 1 - K&N Intake - Forge DV
The Platinum plugs a bit more expensive but last u about 60k think it may work out cheaper in the long run than buying the cheaper plugs
