Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Check coolant warning
    May 2010
    Quote Originally Posted by T Go View Post
    I'm having the same issues over the last 2 weeks also.
    Over here in WA we have had some really cold nights... i think it was 2wks straight under 5deg...
    But... last winter we had some 0deg nights also and this never happened with my car...
    So maybe the coolant level has dropped since then.
    Whens the last time you changed your coolant?
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Mar 2008
    Canning Vale, WA
    Quote Originally Posted by Speed View Post
    I guess it wouldve been looked at with the 30,000km service (am on 38,000km atm), but not changed.....
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    Aug 2007
    Perth WA
    Yep it would be extra chilly in Canning Vale, always seems a bit cooler around there and out towards Jandakot too...
    I've found it the warning does go off, I open the coolant bottle and then it's ok. The coolant level is fine, still well above minimum. I suspect there might be an air leak or something and if there's a bit of condensation of the top of the sensor above the coolant level it goes stupid. Maybe not but once I take the cap off for a few seconds it's ok, bit of outside air etc and the sensor is ok again. Will probably need to replace the bottle as the sensor seems to be moulded in but not too fussed at the moment.
    '04 BMP MkIV R32 #144
    search getnew
