lol . Now someone has learnt that being a mechanic is not easy .
All I can suggest is remove from top and from under the inlet manifold at the same time . Ive got the factory tool so it makes it easier
Can someone give me a clue here.
How do you access #2 and #3 plugs from under
the moulded plastic inlets.
Is a tightly flexing socket driver needed or
is there a secret. My manual doesn't refer to
the problem.
Thanks for any help.
Thanks for reply- so in fact, there IS a special tool
for hooking those middle ignition plugs out from under
the inlet housing. Is the case?
Is it just a flexible drive or more clever than that?n:
