Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Change stereo head unit?
    Jun 2012
    Ic I didn't know that you can use an adapter! well that makes it easier for me to do..thanks guys for your help!
    Talk to you guys soon!
    Jul 2011
    You should check out spares at VW there's a new head unit out that will fit straight into all mk4 vehicles. It has Bluetooth built in, USB, SD slot worth looking at as a factory upgrade. These unit are an extra for the new UP's. sorry forgot the unit code.
    Aug 2012
    The guy at Autobarn told me I needed a European ISO wiring harness with a female plug, but what I actually needed for my Golf MK4 was a male plug so keep that in mind.
    Depending on the head unit you go for, you might also need a car antenna adaptor. I installed a Pioneer unit, and I used this to connect my antenna:
    Car Radio Antenna Adaptor Plug - Jaycar Electronics
    Jun 2012
    yea remy you are right. I got the euro to alpine (16pin) adapter over the weekend and as you said you also need the adapter for the antenna also. Its so easy to do, no worries at all. Thanks guys for all the infos!!!
    Jul 2016
    Perth, WA
    Quote Originally Posted by grtuned View Post
    Hey - is there a link or part number for this head unit?
    May 2015
    Dee Why, Sydney
    you should be able to buy a connector that plugs into the cars wiring loom and the other end to the new head unit's wiring. it will match the wiring order avoiding a lot of cutting and soldering
    May 2015
    Dee Why, Sydney
    oh, there were no visible answers when I first views this topic.......dol!!
    Jul 2016
    Perth, WA
