Hi Guys,
is it possible that my car was running gutless today because of the hot weather??? I cant think what else, apart from the the Vpower filled up with on Tues was crappy.
Its running smooth, just really breathless,I mean its reving but feels like theres turbo lag thru the whole range....(I know its a V6 non turbo, but thats how it feels).
I have hooked up my VAGcom and I got this Engine fault Code:
1 Fault Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded - Intermittent
Also how can I test if my MAF is playing up... do I monitor the airflow g/s values?
Cheers,
Dave
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
Shytzen!!! I have been going to the same servo since vpower came back online....never had a prob.
SO I figure the only options left are :
a. live with it
b. Octane booster
c. top up with BP Ultimate
d. GROUP BOYCOTT !!
Replace the coolant temp sensor and the seal mate.
Alba European
You can look at the output of the temp sensor in measuring blocks, not sure which one though.
If you set it to log and go for a drive then have a look at what you have saved.
Mate block 3 will give you that but that fault is relating to an open circuit or short to ground which in most cases will be inside the sensor.
Jmac
Alba European
In the plastic outlet above where the flywheel would be.
Sensor is about $70 at dealer or about $20 online from US
Easy to change.
It really should not make the car sluggish, just hard to hot -start (at least in my case)
Looking at front of car, sensor is on front RHS of engine
Here you go. http://forums.vwvortex.com/zerothread?id=3386797
I ordered a sensor, clip and o-ring from here
http://www.foreigncarpartsonline.com/
Select the VW link and use 2002/ 2003 VR6 Jetta as your car
Part # is P4036-111921
The last shipment I got from here cost $15 shipping - bloody great
Cheers,
Keith
