Originally Posted by
Stan
also try the key in different positions - i.e. insert key and try to start, if no luck turn pull the key, turn it over and put in the other way. Try with each key.
the reader, as VDMW said, is a loop around the barrel, if it has slipped a bit, it might not read the chip in the key. Same if it is broken or damaged.
Yeah agree here, seems the repair or the damage caused prior. Ive had a few clusters lockup too, that's where your immob is but seeing it had repair in that very area I'd be looking there.
you could hold the spare in various spots near the ignition barrel as you turn the other in an attempt for the reader and key to communicate
Alba European
