Have you checked your earth im the door loom at the flexi joint covered by the rubber boot? When you are checking your main feed for 12 volts what earth are you using your multimeter on? Dont use just thd car body...use the main earth wire in the door. If you are still getting 12v then ok. If no volts or low voltage check your earth wire in the door loom for breaks or cracks.....especially behind that rubber boot towards the inner door end....VDUB...
