Results 1 to 6 of 6
Thread: CanBus adapter for 03 MK IV
    Red face CanBus adapter for 03 MK IV
    Can anyone help.... my daughter has a 03 Mk IV Golf with the standard stereo and wants to replace it with aa Kenwood or Alpine etc. The local stereo guys say we must also install a canbus converter which will be about $200 without labour...
    Does this sound correct? Also do we need to put 6"or 6.5"speakers in the front and rear.
    Thanks for anyones help.
    Apr 2010
    Sydney,NSW
    Not sure about that, unless the '03 Golf is completely different to the '02 Bora. I changed the stereo in my car myself, did not require any convertors.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Jul 2007
    Brissy
    Can bus started with the MK5 AFAIK.
    I have had various audio gear in my MK4 and it wires up just like any other, some models had issues with the K-line, but it is an easy fix.
    Ross-Tech: VAG-COM: Afterrmarket Radio Problem
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    May 2009
    As previously said, mk4s didn't have canbus only mk5s. The plugs are standard black and brown euro plugs too,,just needs two wires switched around but all audio shops should be able to do that with bora fuss.
    Project Hairdresser car DIY build has begun...
    '96 Mirage Track car: BC RM Coilovers, 294mm Galant VR4 Brakes, 5 stud conversion, 16x8 Forged Rays MS01S, UR 23mm sway bar, UR Strut Braces, Evo 5 Recaros, MR Lancer electrics interior conversion, Engine + Exhaust in the works
    Mar 2010
    Lesmurdie
    The only thing in a mk4 thats can bus would be the cd changer. You would need a converter if you wanted that running again. As with others i installed a avic unit into mine with no drama's Just dont hook up the k-line and switch the red and yellow
    Also did anyone else read it as a mk3? Probably not haha
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Apr 2008
    Quote Originally Posted by JustCruisn View Post
    This is correct. There is no CAN-BUS in the Mk4.
    Find another installer.
    Nothing to see here...
