Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Can someone explain my dyno results? PICS
  1. #21
    Oct 2006
    Quote Originally Posted by SoVeReIgN View Post
    Maybe you need a BOV
    I haven't dynoed it since that day it made 125kw, and I've done some more work since then.
    nice nice! just dont put big wheels on lol.. i speak frmo exp! hahah.
  2. #22
    Feb 2007
    Sydney NSW
    This weekend I'm going to spend a day checking all boost/vacume lines and cleaning MAF and testing for leaks. If I don't come up with anything concrete I think I'm just going to have to take it to a shop and say: "I'm down on boost, I'm down on power and car is running rich - fix it"
    Though how much that process actually costs is the bit that worries me
    MK4 GTI | MK5 Sportline | 08 Audi S3
    Modify your ride with free DIY videos at www.mightycarmods.com
  3. #23
    Have a search of all the dyno sheets round this forum and others, you will see the same thing, they all bleed back boost as the rpm climbs as the pissy little turbo cant keep up.
    The AFR's on the other hand as mentioned are more of a concern.
    MkIV GTi
  4. #24
    Feb 2007
    Sydney NSW
    Fixed! Took the car back to Peak who did the original tune and this is what they did:
    Replaced leaking hose on the manifold.
    Changed blow off valve to an S3 DV Valve
    Re-aligned throttle body (had a fault code coming up)
    Remapped the revo tune.
    One, some, or all of the above could have been the culprit but the car is now feeling amazing.
    Pulling hard all the way through the rev range and getting 16psi.
    Gotta say a big thanks to Peak Performance because when I wasn't entirely happy with how it turned out they took the car in and spent a considerable amount of time (days!) testing, and trying different options to get the car running right again.
    I filmed the whole process and will be uploading a video to the mightycarmods site in the next few days outlining how the tune is done and the dyno run afterwards.
    It's good to know everything is working properly as it should and now I can putt to work in the 60 zones knowing that the power that I can't actually realistically (or legally) use is there.
  5. #25
    Dec 2007
    That's good to hear mate. I got my flash done at peak too.
    Could you post your latest dyno graphs? It would be interesting to see where the graphs differ...
    I just installed my boost gauge tonight. I'm getting ~16 psi after a quick test, but i'll have to do some more testing tomorrow and see when it drops off...
    I'm waiting for a stronger (yellow) DV Spring + the n75 Race valve which i should get on Monday (They got to Sydney yesterday...sigh)...then i'll be ready to jump on the dyno again too.
