Results 11 to 20 of 25
Thread: Can someone explain my dyno results? PICS
    Oct 2006
    get rid of the blow valve
    it leaks, regardless you can see it or not
    the spring is much weaker in it and does not hold boost properly
    put your stock dv and try again or get a GFB plumback, if you want sound get an AEM Intake or a like.
    i noticed when i had that bv, i lost 3-4psi
    Jan 2008
    Quote Originally Posted by Jmac View Post
    Think you might be getting a bit mixed up there, 10.6 is richer than 12 mate, head towards Stoich 14.7 and you are lean.
    Jmac
    too true. was on train this morning thinking i got that backwards oopse! it was late
    Feb 2007
    Sydney NSW
    I'm going to go 100% plumback and redyno after checking over the system. Will let you all know results.
    Thanks for the PM's Fuzion and Bug_Racer.
    MK4 GTI | MK5 Sportline | 08 Audi S3
    Modify your ride with free DIY videos at www.mightycarmods.com
    Nov 2006
    Quote Originally Posted by fuzion View Post
    My car has been running perfectly fine with my BOV for ~50,000kms.
    *knock on wood*
    Oct 2006
    Quote Originally Posted by SoVeReIgN View Post
    *knock on wood*
    dave, maybe because i have more mods? who knows.
    what did you dyno at anyhow? as your 24psi from sig, im only 18/19!
    Feb 2007
    Sydney NSW
    Quick update.
    Have made my GFB fully plumback. (The Hyrbid BOV can either vent 50% or you can screw in a cap blocking the atmos port which then recirculates 100%)
    Haven't dyno'd it but just did a run and boost is still the same (max 13psi) and it is still losing boost as it revs out (havn't dont a 3rd gear full boost 150km/hour run like the dyno run) but car feels exactly the same as when it was venting 50%.
    Is there any different between a DV valve and a 100% recirc Blow Off Valve or are they two different names for the same thing?
    Any is it possible that the actual blow off valve enclosure leaks?
    Oct 2006
    Quote Originally Posted by blue_reality View Post
    Quick update.
    have you checked your boost hoses? (intercooler, tip etc)?
    disconnect your maf, go for a drive around the block and see what it comes up to ..b lock your n75 valve hose (kink or something, just dont break it) then go for a run and see again?
    Nov 2006
    No difference, I don't know why some people here call them DVs (diverter valve) when the rest of the world calls them plumback bovs.
    Yeah it is possible, I don't know about yours but most BOVs have an adjustable spring (and a piston that needs to be oiled), if the spring is set too losely then it will bleed off air prematurely.
    Tighten it up if possible, iirc the check is to see if you can see the pison hovering around inside it while the engine is on, it shouldn't be moving at idle.
    Agree with Piere, disconnect your MAF and see how it goes, and try reseting your ECU - Turn car off, unplug your batt, tap the brakes, let sit for 5minutes and plug it back in and see how she goes.
    Nov 2006
    Maybe you need a BOV
    I haven't dynoed it since that day it made 125kw, and I've done some more work since then.
    Boost should be on the side of the piston and therefore not going to lift it off it's seat.
    I don't see how one could leak internally, certainly not enough to be noticeable.
    VW call them DVs why wouldn't we, it doesn't blow off so BOV isn't correct.
