Interesting... I wasn't aware of the need to move the battery.
The CDA itself is fairly big (200mm long, 150mm diameter) so I would think it would be hard to mount it further down then where the factory box currently sits?
I'm going to have a look on the weekend about making these mods to the factory box. I found some great 3" Silicone hose that's smooth inside so that should work quite well.
99GTi, would you mind giving some tips on the mod? As I understand it, you just remove the factory "funnel", shave some little bits of plastic out from the bottom of the box and run the silicone down near the front bar? There doesn't look like there's much room for the hose though??
I wish I could make it for the cruise on the weekend, but i have to work... and Bathurst is on too!![]()
