Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: CAI installation question
    Sep 2007
    Hi guys,
    couple of questions... I'm looking to install a BMC CDA air intake.
    The model that i'm looking at says it's specifically for cars that have a MAF part number of PBT-GF30. I checked mine and it says PBT-GF on the top, but nothing else?? Does anyone know if there were multiple versions?
    Also, given that I plan on removing the factory airbox, I notice it has a sensor of some description on the side. What's this for? Does it need to be retained?
    Cheers guys!!
    May 2007
    Moonee Ponds
    Let me know if you get one, because I believe they are out of stock at the moment
    Sep 2007
    Yeah, I was told that too...
    I've found a source in Europe that have 2 models. One is the generic fit CDA85-150 with a 70mm joiner. The other is the CDA SP-05 which specifically states the 1.8T 150/180 and is designed to mount directly to the MAF.
    Cost was just over $400au landed.
    Sep 2007
    Anyone????
    The thing with 2 plugs on it in the side of the air box lid is an ignition amplifier I believe.
    Can't answer your question on the MAF, I do know that the 150 and 180HP engine have a 2.5 inch housing and the 210-225 hp models run a 3 inch. I wonder if that's the numbers you are looking for?
    gpk_gti Guest
    as ive had a few tonight I cant answer your question fully,but the amplifier that is bolted on the side is a temp sensor.leave it hanging away from anything that will make it hot.pm dub20v as he has a CAI setup and should be able to answer most of your questions.
    if I think of anything more ,ill post here when I sober up tomorrow!
    May 2007
    Moonee Ponds
    Will the generic one fit on the Bora V6 ? 400 $ landed is dirt cheap ... maybe a group buy....
    Sep 2007
    I'm not sure... The BMC website states that it is for cars over 1600cc, so I guess it fits that criteria...
    Here is a link to the generic one
    http://www.bmcairfilters.com/VisDetail.asp?ID=203
    And the specific model for the Bosch PBT-GF30
    http://www.bmcairfilters.com/VisDetail.asp?ID=212
    Here is a list of all MK4 Golf/Bora models
    http://www.bmcairfilters.com/VisModel.asp
    Interesting they specify the 150hp ans 180hp models differently? Do our cars need/have a crank case filter?
    May 2007
    Moonee Ponds
    What do you think of the Carbonio ? There is quite a selection out there. I guess you have to go with whatever is marketed best
    Sep 2007
    Can't say i've really looked into the Carbonio too heavily, as I want something that doesn't sit in the front footwell. I've heard (not experienced, not backed up however) about hydro-locking etc, so would like something enclosed.
    I like the BMC too as although it has the carbon case, it doesn't look too blingy and aftermarket.
    I'm going ahead and ordering 2 of these in (the CDA85-150), so if anyone is interested in the second one feel free to PM me. Cost will be $420 landed, which is pretty good as I was quoted around $650 locally + installation. I believe the only other part required will be a silicone adapter to go from the 85mm BMC to the 70mm MAF intake. These can be picked up from virtually anywhere.
