Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: A/C regassed still not blowing cold
  1. #21
    Feb 2010
    Launceston, tas
    So I was digging around in the old engine bay last night and came across this
    Dunno I it has anything to do with the a/c but surely it's meant to be plugged somewhere! But I couldn't see where?
  2. #22
    Jul 2007
    Brissy
    Quick don't touch that what ever you do !!
    it does absolutely nothing at all.
    It is an electrical connector that connects to an plastic part. Has no purpose that I could ever find. I tested it once and it had voltage.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  3. #23
    Feb 2010
    Launceston, tas
    What the? Really?? Thanks vw!
  4. #24
    Jul 2012
    I found that tonight as well (doing rear wiper delete) wondered what it was for!!!
  5. #25
    Jun 2011
    on my 03 sport there is a clip that leads to bonnet catch microswitch. the plug like that one is just above the RH headlight on upper radiator support.
  6. #26
    Aug 2007
    Fans are reqd to cool the condensor, temp is related to pressure so if the temp goes up then the pressure does too, too high itll trigger the high pressure switch and shut your aircon off, if it didnt have such system you would have a hose blowing to bits under high pressure, thats why you have fans on. This is the case for EVERY AC system, ANYWHERE. Ok the compressor in your car can still have the clutch pulling in buit internally it can still be stuck, it is a variable displacement compressor, if it were the case the guy gassing it up should be able to tell . With the gauges hooked up you can see if the high and low are right or not, when its stuffed there is no reaction to the clutch kicking in,m it just stays static, its the only way to test it, if you find this is the case then the compressor is the culprit. If the clutch is kicking in itll be fair to say the connection at the fuebox on the battery will be ok. If the fans are coming on then itll be fair to say the ECU controlling them is good too. Full of gas and not cool can then only be a bad compressor or a blend door staying open in the cabin bleeding hot air with the cold
    Jmac
    Alba European
  7. #27
    Mar 2009
    Sydney boy
    Hi Jmac seems like you understand the aircon stuff,Iv got a question for you.
    What does it mean if on a cool day i have a/c working but the fans seem to spin alot faster (louder), And on a warm or hot day when you really want it the a/c doesnt work.
    The high pressure is at 100psi and low pressure valve showed 80psi and when they tested the pressure it was a hot day so now a/c.
    In december i had a tow bar go through the radiator and condensor which was replaced new.
    Iv been to 2 places and they seem to be lazy to have proper look and just stare at it and say youl need to bring it another time.effin annoying.
    Thanks for your info
  8. #28
    Sep 2009
    The Fan speed depeding on your model is based upon A/C system pressure. Some models have a high pressure switch which turns the fans to High speed when the pressure reaches 16 Bar. The other type of sensor transmits a signal to the ECU which then decides how best to manage things. FYI the a/c system high pressure cut-out pressure is 32bar, with a reset point of 24 bar.
    If you have a high side pressure of 100psi and low side of 80 with the compressor running something is wrong. Maybe an issue with the expansion valve, or the compressor itself. Really you need put a set of gauges on it with the a/c system off then turn it on and watch the gauges and see what they show. Normal High Side should be in the region of 16bar with the low side around 1.5-2.5 bar. (dependant on ambient temp)
  9. #29
    Mar 2009
    Sydney boy
    Thanks heaps Who,
    Im going to take it to a reputable a/c place and see what happens
    Cheers mate
  10. #30
    Feb 2010
    Launceston, tas
    got my mate to chuck his guages on it last night, we got Low 60 psi and high 290 psi. The fans seem to kick in on high speed sometimes when I have the engine running and switch the A/C on. They spin on high for about 5 seconds or something? Then they just stop. Is my compressor stuffed? Or should I be looking and the fans first to make sure they are functioning on high and low speed correctly.
