Thanks for the replies! I'll have to get out and have someone flick the ac on go me to check all this!
If the fans don't cool the gas then what purpose to they serve???
checked my fans last night, couldn't get them to spin after numerous times getting someone to flick the A/C on and off. Got them to spin only once, but not for long. Is it weird that neither of them spun?
not wierd, broken, with the car running, and the ac on, both fans should spin
Testing the fans is easy watch this video VW Golf Mk3 VR6 - How to Test Radiator Fan - YouTube
If they do low and high the problem is not the fan but something else.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
low and high problem is something else, the temp sender to the fans or the fan control module.
No fans at all - fuse or fan resistors, or dud fans.
I have one fans working, one not- one dud resistor, if this keeps up, the second one eventually goes and you lose the lot - fans and ac
i think the temp sensor is a 3 pin plug that is on the bottom left of the radiator area. check my links above, some great info there
