Here's the instructions:
Air flow flap motor -V71-, removing and installing
Removing
- Remove glove box.
- With screwdriver, carefully unclip air flow flap rod from lever.
- Disconnect electrical connector.
- Remove screw.
The flap motor is connects to the evaporator housing portion of the heating and A/C unit. To prevent damage:
- Lower flap motor and at the same time pull off fresh air/recirculating air flap shaft.
So it would 'seem' that it's not that hard...however looking at posts from vortex it took 1 guy 7 hours!!! Another guy said it took a while and was a lot of fiddling around
http://forums.vwvortex.com/zerothread?id=1539217&page=1
Let me know if you want the part as I'm looking into a group buy
