Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
Thread: Buying a Mk IV
  1. #21
    oettinger and sport models are not linked.
    it just seems a lot of sports models got landed with the oettinger grille and spoiler and other random bits.
    ill try find my oettinger parts list so you can see all the bits and scary prices
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #22
    Apr 2013
    RED!!! nahhhhh. haha
    Trying to avoid a trip to Syd, if i were to go to Syd, I'd buy Manaz.
  3. #23
    MOTOR-TECHNIC
    Part No. Description Retail
    AUD
    NEW OETTINGER CARBON LINE incl GST
    OE 340 010 00 CARBON-ALU STRUT BAR - for 1.8 Turbo engine $599.00
    OE 722 051 00 CARBON "ENGINE COVER" - for 1.8 Turbo engine $650.00
    OE 722 055 00 CARBON „AIR INTAKE SET“ - for 1.8 Turbo engine $699.00
    OE 722 056 00 CARBON „AIR INTAKE SET“ - for 2.0l engine $699.00
    OE 722 059 00 CARBON „AIR INTAKE SET“ - for 1.9 TDI engine $699.00
    OE 108 401 00 INTAKE PIPE- 1.8 T, AUM, approx. 4-5 kW (5-7 hp) extra $499.00
    OE 108 388 01 INTAKE PIPE- 1.8 T, AGU/ARZ, approx. 4-5 kW (5-7 hp) extra $499.00
    BODY STYLING
    OE 804 226 00 FRONT GRILLE $450.00
    OE 804 227 00 FRONT SPOILER- replaces standard lower spoiler lip $795.00
    OE 804 228 00 FRONT SKIRT Large lower fiberglass bar - attaches to original $1,050.00
    OE 804 219 00 SIDE SKIRTS- set $895.00
    OE 804 229 00 REAR SKIRT- replaces standard lower rear skirt, Saloon/Sedan only $795.00
    OE 804 251 00 REAR SKIRT- replaces standard lower rear skirt, Variant/Wagon/Estate only $795.00
    OE 804 238 00 ROOF SPOILER- Saloon/Sedan only $595.00
    OE 804 230 00 BOOT/DECK LID SPOILER- with brake light, Saloon/Sedan only $950.00
    OE 804 231 00 BOOT/DECK LID SPOILER- without brake light, Saloon/Sedan only $850.00
    OE 804 232 00L SPORTS MIRRORS- left and right (set), LHD only. $995.00
    OE 804 232 00R SPORTS MIRRORS- left and right (set), RHD only. $995.00
    STAINLESS STEEL EXHAUST SYSTEM
    OE 111 204 00 SPORTS REAR SILENCER- for all front wheel drive $1,495.00
    OE 111 188 00 ADAPTER FOR REAR SILENCER - please use for 1,4 l + 1,6 l + 1,9 l SDI engines $69.00
    1J0 253 144 BRACKET FOR REAR SILENCER - please use for 1,4 l + 1,6 l + 1,9 l SDI engines $39.00
    OE 111 199 00 DOWN PIPE - for 1.8 T $995.00
    BRAKES
    OE 350 015 00 UPRATED FRONT BRAKE KIT- 320 mm front discs with 4 pot calipers $5,495.00
    Caliper in black, red or yellow. Min. wheel dia. = 17"
    CHASSIS
    Saloon/Sedan, Front wheel drive
    OE 410 062 00 SPORTS SPRINGS- 4 springs - 1,4 l + 1,6 l $595.00
    OE 410 063 00 SPORTS SPRINGS- 4 springs - 1,8 l (not GTI) + 2,0 l + $595.00
    all TDI up to 81kW with Manual/Stick shift
    OE 410 064 00 SPORTS SPRINGS- 4 springs - GTI + V5 + TDI 85 kW + $595.00
    all TDI Automatic up to 81kW
    OE 410 077 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,4 l + 1,6 l $2,195.00
    OE 410 078 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,8 l (not GTI) + 2,0 l + $2,195.00
    OE 410 079 00 SUSPENSION KIT- 4 springs/shock absorbers - GTI + V5 + TDI 85 kW + $2,195.00
    Variant/Wagon/Estate, Front wheel drive
    OE 410 082 00 SPORTS SPRINGS- 4 springs - 1,4 l + 1,6 l $595.00
    OE 410 083 00 SPORTS SPRINGS- 4 springs - 1,8 l (not GTI) + 2,0 l + $595.00
    OE 410 084 00 SPORTS SPRINGS- 4 springs - GTI + V5 + TDI 85 kW + $595.00
    OE 410 085 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,4 l + 1,6 l $2,195.00
    OE 410 086 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,8 l (not GTI) + 2,0 l + $2,195.00
    OE 410 087 00 SUSPENSION KIT- 4 springs/shock absorbers - GTI + V5 + TDI 85 kW + $2,195.00
    FRONT WHEEL DRIVE, all version
    OE 410 132 00 ADJUSTABLE SUSPENSION KIT- in stainless steel, without hardness adjustment $2,995.00
    Front- height adjustable, max 65 mm lower
    Rear- height adjustable, max 65 mm lower
    OE 410 131 00 STABILISATOR-SET-consisting of stabilisator and 2 x self-aligning bearings, $595.00
    please use for lowering with OE 410 132 00 of over 40 mm (Sway Bar Front
    4Motion, all version
    OE 410 130 00 ADJUSTABLE SUSPENSION KIT- in stainless steel, without hardness adjustment $3,295.00
    Rear- height adjustable, max 50 mm lower
    OETTINGER ALLOY RIMS
    OETTINGER 18-inch, Type RE, 1-piece rims
    OE 361 146 00 TYPE RE "silver" - 8.5 x 18, 35 mm offset, PCD 5 x 100 $825.00
    OE 361 152 00 TYPE RE "charcol-silver" - 8.5 x 18, 35 mm offset, PCD 5 x 100 $825.00
    OETTINGER 19-inch, Type RE, 1-piece rims
    OE 361 149 00 TYPE RE "silver" - 8.5 x 19, 35 mm offset, PCD 5 x 100 $945.00
    OE 361 155 00 TYPE RE "charcol-silver" - 8.5 x 19, 35 mm offset, PCD 5 x 100 $945.00
    OE 361 138 00 TRACK SPACERS- 2 discs 5 mm each, set for one axle - for Oettinger type RE wheels only $365.00
    OE 361 135 00 TRACK SPACERS- 2 discs 8 mm each, set for one axle - for Oettinger type RE wheels only $365.00
    OE 361 117 16 TRACK SPACERS- 2 discs15 mm each, set for rear axle - for standard Audi wheels only $365.00
    OE 361 132 00 SECURITY WHEEL BOLTS- for Oettinger type RE wheels only $179.00
    OE 361 133 00 SECURITY WHEEL BOLTS- for fitting with spacers OE 361 135 00 or OE 361 138 00 $179.00
    INTERIOR
    OE 551 007 00 FLOOR MATS- set of 4 in black, charcol, blue or red, LHD / RHD $395.00
    Please give model year when ordering
    OE 722 037 00 ALUMINIUM GEAR KNOB- from 1,8 l on with Manual/Stick shift $295.00
    OE 722 049 00 ALUMINIUM PEDAL SET- set of 3, for manual transmission only- for RHD only $395.00
    OE 722 051 00 ALUMINIUM PEDAL SET- set of 2, for automatic transmission only- for RHD only $395.00
    OE 722 045 00 ALUMINIUM FOOT REST- for RHD only $325.00
    OE 804 236 00 DOOR SILL- set of 4 in aluminium look $299.00
    OE 804 236 01 DOOR SILL- stainless steel, set of 4, for 4-door $299.00
    I know for a fact there is more bits to this as iv seen a oettinger 4mo exhaust and lower grilles with my own eyes
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #24
    this list is from back in '06
    no GST on prices, prices dont include painting etc
    appears this is a US list even though I got it from a AUS supplier looking at the engine models
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #25
    Apr 2013
    Aghh okay, yeah it would be pretty interesting to read up a parts list of the oettinger gear.
    I hate those pox spoilers, the bora arse looks so good without it.
  6. #26
    Apr 2013
    DAMN? those prices...
    Looks like it may be in my interests to invest in one with a few of those Oetty options.
  7. #27
    Quote Originally Posted by xpeesx View Post
    haha. a fat girl never looked so good
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #28
    Apr 2013
    haha too true, AWD also, cause we all know a fat girl likes a little more traction in the mud.
  9. #29
    Jun 2012
    If you could find them new now... Used will still be costly. I remember when the front GLI valance jumped from $96 to $300 over night. Same with the vortex rear valance.
  10. #30
    Apr 2013
    Quote Originally Posted by skid plate View Post
    I shouldn't complain about part prices, i own a Mercedes. haha
