Results 11 to 20 of 31
Thread: Broken down in maccas drive-thru!!!
    Feb 2010
    Launceston, tas
    Is there a way I can check that? Guessing that would be a simple fix that I could do myself?
    I am thinking ignition amplifier. The one in the airbox. Really to be fair the best way forward, is to scan it with VCDS and go from there. Speculation won't fix it quickly. Certainly, if you can find a similar car, you can swap the ignition amp in dead easy.
    Jan 2010
    west melbourne
    sounds very much like fuel pump to me. i had the EXACT same symptoms (all be it in a different car) and it turned out to be the fuel pump.
    Aug 2009
    Vic
    did it have a Mcfish?
    if so, there's your problem.
    McFish will kill anything
    Feb 2008
    mOOROOLBARK
    check the fuel pump relay first.
    Feb 2010
    Launceston, tas
    I can't scan it cause I don't have the stuff to do it. Maybe I'm better off forkin out some cash and takin it somewhere? Sounds like it's either fuel pump or relay or ignition amplifier? I guess if it's some kind of switch or relay or something along those lines it's not a big job. I hope!!!
    It's dead easy to check the ignition amplifier. Remove the coilpacks and plugs, then stick the plugs back in the coilpacks with them connected to the loom, they need to be grounded, the cam cover will do. Flick the key while watching for sparks.
    Dec 2008
    Northern Suburbs
    Quote Originally Posted by JustCruisn View Post
    Crank angle sensor is my guess.
    agree, scan the car before you waste your time fidling with other stuff.
    On the road
    ok... low tech posibility... what condition is the fuel filter in?
    And he's stated that ha doesnt have the kit to scan the vehicle...
    "Stupidity is the only universal capital crime; the sentence is death. There is no appeal, and execution is carried out automatically and without pity" R. Heinlein: Time Enough For Love
    Feb 2010
    Launceston, tas
    yeah i need to get the stuff so i can scan it, Where can i buy that from? Not sure on the fuel filter, I've had to borrow the mrs's magna for the weekend and havn't been able to check anything on the car other than the ignition amplifier like gavin said, and there is sparks. Hopefully i can drive it to work in the morning, then after work AGAIN if i can start it, drive it to my local mechanic and get him to scan it if he has time, or just leave it with him! don't want to get stuck on the highway or something. or at some traffic lights! could be awkward.
