Shouldn't be a problem i think. The abs is just a sensor at the back and doesn't interfere with the pads.Only thing that might be different are wear indicators which is just a connector to disconnect. I would say if you've done it before you should be fine.
Heres a manual should you need it.
1999-2005 Volkswagen Jetta, Golf, GTI Service Manual | Free PDF Download
