Results 1 to 10 of 12
Thread: Bora v6 starting troubles???
Threaded View
  1. #10
    Feb 2014
    Batemans bay
    your problem is micro switch in drivers door..... All the symptoms you say relate to this switch .... Stick a can of contact cleaner in the door lock and squirt away ... It may fix it or otherwise you can replace just the switch or the entire internal lock ....
    my 4motion on a cold start idles around 1500 for the first minute or so until some sort of sensor warms up or gets a signal to drop the cold start assistance ....
