Results 1 to 10 of 11
Thread: Bora V6 Headers, anyone seen/heard of these?
    Mar 2011
    Kew, VIC
    Hi Folks, found these the other day...look strangely cheap to me. i also emailed these folks to confirm if these are for the 24v VR motor. said they are...not sure...
    TOP SPEED AUTO ACCESSORIES, INC.
    from what i have read, any gains would probably be marginal, but...still interesting...group buys perhaps...
    Apr 2011
    Ipswich, QLD
    I too was looking at these and from the research I have done the potential gain is indeed quite small if anything. The stock exhaust manifolds flow quite well, the restriction begins in the down pipes and continues from there. For a nice note and a marginal power increase a cat back system will do the job fine, for all but N/A race applications a custom DP and high flow cat would give you the best street performance.
    Extractors may give you that old school sound but even at the exceptionally low cost I dont think they are worth it, but I am happy to be proven wrong
    2003 Bora 4Motion
    Jan 2008
    Newcastle, NSW
    I'll happily provide you with a FULL Mk4 R32 exhaust for a small fee to increase the performance and sound of your Bora
    Sep 2009
    The exhaust ports on a 24v are equally spaced. The ports dont look equally spaced in the photo they have given thus i'd be skeptical that they are actually for a 24v. Get them to send you a photo of the actual item they would send to be sure.
    Jun 2008
    Cronulla, NSW
    Quote Originally Posted by schoona View Post
    can SOMEBODY please listen to schoona here and freaking buy the full system!!
    Full system = R32 headers all the way back to the tips. craziness. Wish i could have bought that for the extra r32 goodness.
    +1 for the mad sound too.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Mar 2010
    Lesmurdie
    Apparently the stock headers flow decently enough to not worry about it as others have said.
    How much, I'm interested.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Mar 2011
    Kew, VIC
    Indeed. r32 option sounds good. how is fitment? anyone aware of any special work that needs to be done to get the full sys in?
    Apr 2011
    Ipswich, QLD
    You need to extend the pipe from the cat to accomodate the longer wheel base on the bora, then you need to work out how you will tackle the dual tips as the R32 has both sides of the car. I have seen mods down that run an extended pipe for the right hand side back around the spare wheel well to the stock valance on the left hand side. Or you can get an after market bumber / custom valance to allow the tips on each side or even go full stealth and cut the tips off and dump them behind the bumper.
    All in all its a bolt on mod and they do sound fantastic if done right.
    2003 Bora 4Motion
    May 2010
    Perth
    pretty sure there isnt much difference between the 2.8 and 3.2 headers, so thats a whole lot of work for very little gain.
    Note that the US cars only have 2x O2 sensors, and the euro/oz have 4. Ecu will likely throw a fault code if they arent in similar positions to stock (one pair before cats, one pair after) unless you have it coded out.
    Those aftermarket ones look ok, but hard to guage how much more power one would make, i dont think they are the most restrictive part of the motor. If it was opened up with cams, headwork, ecu, compression etc I would look at doing them however.
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by Back Door Shenanigans. View Post
    Hoihoi,
    $500 + shipping, I think is a pretty good deal
    Mal
