Results 1 to 10 of 12
Thread: Bora V6 4motion super high fuel consumption
    Mar 2018
    Southbank,Melbourne
    Hi Everyone,
    I've recently bought this car and had it serviced, new tires, oil, filters, A/C, ESP sensors, CV shaft!
    Spent around 2K just fixing the car, I am happy with the way it drives but fuel consumption is extra ordinarily high
    I was reading about the possible issues and found this on carsguide website :
    they can also have trouble with engine electrics with airflow meters and oxygen sensors. The latter can send the fuel consumption rocketing if they fail, and may not send any signals to the driver that there’s a problem while driving.
    No error comes up when scanning, do you still think that it could be the issue?
    P.S Current Fuel consumption is more than 20L/100KM. (Driving very conservatively)
    Apr 2014
    Penrith, NSW
    I get about 450kms per tank city driving.. what are you getting atm?
    Mar 2018
    Southbank,Melbourne
    Quote Originally Posted by beale187 View Post
    Wow, That's good. I am getting 250KM per tank
    The coolant temp sensor often fails on mk4s (V6 and 1.8T alike), which can cause rich mixture and high fuel consumption. Worth checking out I think.
    Apr 2014
    Penrith, NSW
    250kms/p tank Eww.. that's messed up.
    You could try cleaning the MAF gently with a clean lint free rag and some electrical contact cleaner. Same goes for the O2 sensors Although I don't think they're expensive so perhaps replacement is in order.
    Have you checked your plugs?
    Mar 2018
    Southbank,Melbourne
    good points
    Thanks guys ,
    I ordered an OBD scanner off Ebay
    Gonna monitor the fuel efficiency and do a bit of research once I received it. I will share my findings
    Apr 2014
    Penrith, NSW
    I bought this a while back and it works awesome and is 1/10 the price as the original.
    VAG-COM VCDS 2018 - OBD2 Diagnostic Cable & Software (for VAG Cars: VW, AUDI, SEAT, SKODA)
    Mar 2018
    Southbank,Melbourne
    Too late mate, already bought this :
    http://r.ebay.com/5nRNQG
    I can return it if it didn't work properly, will order the one you sent
    Mar 2018
    Southbank,Melbourne
    I ended up ordering that one, waiting for it to be delivered
    Mar 2018
    Southbank,Melbourne
    Hi mate,
    I bought that device but have some connection issue and it says no interface, will sort that out with their support but just realized with VCDS can't program new keys.
    Have you ever tried connecting to Vag Tacho software with that device?
    are they compatible?
