Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Bora V6 4motion super high fuel consumption
    Apr 2014
    Penrith, NSW
    There is a certain process to gaining connection (which I always forget).. From memory, you need to
    Disable your WiFi on your PC.
    Car will need to be switched off
    Connect the cable
    Open VCDS
    Turn the key I think to "ACC" (reds on) or Start the car
    Then in VCDS you need to go to Options and run a test to ensure connection.
    If you're doing an Auto-Scan don't forget to select your chassis (1J2 for Bora's) it won't auto-detect
    Have you looked at this, I was under the impression you could match keys in VCDS?
    Immobilizer III Key Matching (Cluster) - Ross-Tech Wiki
    RE: VAG Tacho, haven't used it can't comment.
    Mar 2018
    Southbank,Melbourne
    Quote Originally Posted by beale187 View Post
    Connect the cable
    Open VCDS
    Thanks mate, the problem is VCDS does not retrieve the immobilizer pin. VAG Tacho does which I am not sure if it needs its own connector or I can use the Ross-Tech USB connector
