Cheers for the kind words lads
Back to Jimmy again shortly.
Saw Bora on the freeway on the way to Dyno Day - looks fantastic on the road. Very classy.
And a few more Dyno Day shots...
A Bora that thinks it's a GT-R
Hook me up lads
did you pull the fuse or just lift the handbrake for FWD only?
And did I miss your output figures?
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
No no, fuse was out Dave.
And for your viewing pleasure, my charts are on p. 17 of the Dyno Day thread![]()
153.3hp which is 114.3kw at the wheels. as i remember you got 126kw dave
'01 VW Bora V6 4motion - gone
17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
The manual states 201hp (150kW), take around 30% for Haldex and driveline losses to give 143hp. So while I am only 10hp up after the flash, the torque figure more than makes up for it
As for the exhaust upgrade, they're just Pierre's Oettinger tips! Although Jimmy did mention investigating a better rear section to remove some of the restriction.
When you figure I fitted a full V6 STi exhaust to my last Liberty for only $400, I can't really justify spending between $1200-1500 for a custom or SuperSprint exhaust for the Bora. An EVO Motorsport intake, on the other hand...![]()
I've been quoted $850 through a mates shop for a custom stainless steel catback....they said they could build one that would be very similair to the $1300 Remus systems, hopefully sort it out in the next week or two. Do you think the intake is worth it as I keep reading conflicting stories?
