Page 12 of 12 FirstFirst ... 2101112
Results 111 to 115 of 115
Thread: Bora V6 4Motion - Is nice, I like.
  1. #111
    Aug 2007
    Five Dock, Sydney
    Quote Originally Posted by Gravey View Post
    I've been quoted $850 through a mates shop for a custom stainless steel catback....they said they could build one that would be very similair to the $1300 Remus systems, hopefully sort it out in the next week or two. Do you think the intake is worth it as I keep reading conflicting stories?
    due to the rear drive assembly there isnt a lot of room for the muffler to face directly rearwards, so the 4mo Bora rear box is designed similiar to the R32, and sits across the back. This adds to the cost of custom boxes due to additional "donut" sections, mandrel bends parts and labour.
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
  2. #112
    Mar 2009
    Southside, South Australia
    I see - that makes sense!
  3. #113
    Blackburn South, Victoria
    Quote Originally Posted by vert1 View Post
    Did you guys not get the Xenon lights on the Aussie spec Bora 4M?
    All the jap imports we have here came optioned with them.
    nope, we got screwed over here in Aus.
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
  4. #114
    Sep 2008
    bne.qld.au
    You're right Dave, as my other option is bolting in an R32 rear section?
    Though this could get expensive with the amount of custom pipework involved, blanking off/rerouting the dual outlet to the cutout on the passenger side of the rear valance in the Bora... And a decent custom system is the wrong side of $1k? Hmmm...
    Most importantly, it would be good to know if there are any solid gains to be had in fitting the R32 item, as it would be a bit pointless swapping out the rear section for an R32 jobbie, only to discover it flows the same as the existing one?
    If that turns out to be the case, I think I'd rather spend that money on drivetrain upgrades like a better clutch and flywheel, for example.
    As for the intake, it will run an OEM filter but flow more efficiently than the OEM airbox.
  5. #115
    Sep 2008
    bne.qld.au
    So as you may have read here, I finally got around to organising the HALDEX service (thanks for the reminder Jimmy ) as well as adding some very worthwhile and long-awaited upgrades including a new TT metal impeller water pump (Kolbenschmidt stylz yo), a DG 6 speed shortshifter and the TyrolSport brake kit from Dave's recent GB. Also had the perished aerial seal replaced along with the base.
    First the good news, and that's that JMac managed to get the old (plastic-toothed) pump out just in the nick of time, as it had thrown three blades and was looking a bit ordinary, although not entirely shagged, after 150k of faithful service. The stock pumps certainly have their work cut out trying to keep the 2.8 lump cool and it had performed admirably but certainly needed to be swapped. I'd hate to think what would have happened had the other fins let go...? I'm confident the new metal-finned item should perform the task with far greater efficiency.
    The DG shortshift kit is a bit of a revelation and makes for a more positive feel and action for Borat's 6 speed 'box. For anyone who's driven one, it reminds me of the old Fiat X/19 four speeders that needed nothing more than a firm wrist to swap between cogs: anything more hamfisted resulted in you either miss-slotting, or sitting there with the raspy twin-cam revving away with a handful of neutrals! The SS kit rewards a positive, methodical action and forces you to rid yourself of the lazy technique associated with the sloppiness of the rubbery OEM shift.
    To be honest, I really didn't know what to expect with the TyrolSport brake kit but this, too, has proven to be a fantastic upgrade. The feel now reminds me of the brake set-up on my previous Liberty, which ran slotted WRX 4 pots and a Cusco brake booster. The inclusion of TyrolSport's kit means a far more immediate and firm braking feel that also allows better modulation during enthusiastic downshifts. The results is a more direct pedal feel which actually requires far smaller and more precise inputs as the calipers are no longer twisting under force, so far less braking effort is lost through the less than ideal OEM design.
    After almost two years of careful and considered mods, I'd never have expected the Bora to have come together as such a fun, focused package.
    Is nice, I like
    And I know you're all sick and tired of hearing it, but JMac FTMFW
