Cheers for the kind words lads
Back to Jimmy again shortly.
Saw Bora on the freeway on the way to Dyno Day - looks fantastic on the road. Very classy.
And a few more Dyno Day shots...
A Bora that thinks it's a GT-R
Hook me up lads
did you pull the fuse or just lift the handbrake for FWD only?
And did I miss your output figures?
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
No no, fuse was out Dave.
And for your viewing pleasure, my charts are on p. 17 of the Dyno Day thread
153.3hp which is 114.3kw at the wheels. as i remember you got 126kw dave
'01 VW Bora V6 4motion - gone
17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
The manual states 201hp (150kW), take around 30% for Haldex and driveline losses to give 143hp. So while I am only 10hp up after the flash, the torque figure more than makes up for it
As for the exhaust upgrade, they're just Pierre's Oettinger tips! Although Jimmy did mention investigating a better rear section to remove some of the restriction.
When you figure I fitted a full V6 STi exhaust to my last Liberty for only $400, I can't really justify spending between $1200-1500 for a custom or SuperSprint exhaust for the Bora. An EVO Motorsport intake, on the other hand...
I've been quoted $850 through a mates shop for a custom stainless steel catback....they said they could build one that would be very similair to the $1300 Remus systems, hopefully sort it out in the next week or two. Do you think the intake is worth it as I keep reading conflicting stories?
