Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Bora V6 4motion DIY Service
    Mar 2010
    Lesmurdie
    Quote Originally Posted by grtuned View Post
    Simple if you got leads running to your plugs then you got one coil pack.
    Sent from my iPhone using my fingers.
    Huh? Both will have leads running to the plugs. A coil pack will have leads running to a "square" on the side and straight to spark plug. Thr individual coils are on top of the spark plug and should run into a wiring loom.
    Coil pack
    Individual coil on the right and normal on the left.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Jun 2009
    Melbourne, VIC
    Finally received my ECS shipment and was wondering about ignition coils - if one goes bad will it ALWAYS result in a misfire (therefore a misfire code)? ..or can an ignition coil be "half bad" and sort of work and not cause a misfire, just loss of power without the roughness?
    From what I know the ignition coil is either good or bad, no in between symptoms. If so, changing my coils would just be preventative maintenance.. (I did recently have a failed coil but it was replaced with another used one)
    ---------- Post added 17-04-2012 at 02:12 PM ---------- Previous post was 16-04-2012 at 09:51 PM ----------
    Just did some research and found the answer. For those that don't know a coil pack is like a light bulb, either works or doesn't- so no in between (not 110% sure on this though).
    In my Google travels I also read up on the MK4 coil pack recalls and that people were still able to get them changed for free by VW dealers in the present time. I called up VW customer service and there were never any recalls for my car =( I'll proceed and change my ignition coils tonight..
    VW Bora V6 4motion
    Apr 2008
    Quote Originally Posted by jpflorez View Post
    There was a service item on the 24v VR6 engine in the US to replace all individual coil packs, but that service item didn't make it to Australia - only the R32 got it here.
    Nothing to see here...
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by Manaz View Post
    Yeah that sucks! Damn those yanks.
    VW Bora V6 4motion
