Results 1 to 2 of 2
Thread: Bora V5 - whining noise from air con
    Apr 2010
    Sydney,NSW
    Hi,
    My 2002 Bora V5 has an occasional whining noise at idle, the best way to describe it is the sound you get when running a wet finger around the rim of a wine glass! It is not constant, seem to change tone then stops if I accelerate. Yesterday I found that if I hit Econ then it stops instantly.
    Is this likely to be a fan or the air con compressor? Doesn't sound like the squeal of a belt slipping.
    Any thoughts?
    Thanks,
    Adam
    Apr 2010
    Sydney,NSW
    Any thoughts on this?
    I have been running without the aircon on for the last week and there has been no noise, today I went out at lunchtime and it was hot so needed it on, almost as soon as I put it on it started whining again, still only at low rpm. Now either it is one of the fans attempting to move but can't or .... ?
    I am hoping it is not the compressor itself. The air isn't very cold either. Could this be a sign it needs regassing? I am not sure what the symptoms are for that.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
