Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Bora V5 suspension options
    Apr 2008
    I assume you're entering and exiting on an angle to reduce the effective approach/departure angle issues?
    Nothing to see here...
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by Manaz View Post
    Not much space to do that, the entrance is only about 1.5 car widths with a wall each side. If I take it really slowly then it usually does not touch, if it does it only grazes the lip anyway.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Mar 2009
    Southside, South Australia
    Quote Originally Posted by Rybky View Post
    Gravey, from the pics it looks like the drop was mainly at the back, front looks about the same to me. Is that the case? Or did the front drop too?
    Would like to lower it but really can't, the front lip just licks the concrete now as I enter the underground parking.
    Adam
    yeah it really just evened the car up, though the front did drop a bit
    2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
    MY15 Golf Wagon Comfortline
    Aug 2007
    Five Dock, Sydney
    I found the same effect when I installed R32 springs in my Bora, the rear dropped noticably but the front stayed relatively the same, with very minor drop.
    If this is the case, then it might actually help your cause as the approach angle is slightly increased as the rear drops
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    I would question if any part of the block is built to any standards!!!
    My understanding is that the V5 and 4mo actually sit at the same height, definitely lower than the 2.0, I remember reading a V5 review that specifically called this out.
    I don't think there is anything lower than the lip behind it, the lip just touches as the wheels hit the change of angle, so from then on it lifts again as I move forward anyway.
    Come to think of it, someone in my block has a Boxster that gets in ok, so maybe my springs have sagged a lot!!
    Adam
    measure your car and see how high it is, there is diagrams floating around showing what it should be from memory (had it as my background on my old PC) do to the front lip and find the lowest point on the car (im sure youll find its lower). someone else pointed out a while back that their golf was at 120mm or something clear BEFORE lowering due to sagging, so could be the case.
    just because i can get the front lip over something doesnt mean i can get the rest of the car. only place i hit the front lip is a small ramp into my own carport, go over 5km/h in and you here it touch. like you there is no room to take it at a angle. I have to take work and our local maccas slow at 45o angle otherwise i hit the front lip and everything. then on the way out the front lip clears the speed bump but the rest of the car doesnt (no more maccas drive through for meeee)
    Apr 2010
    Sydney,NSW
    I would expect that the lowest point will be the sump but as that is between the wheels it should only bottom out if the ground is higher between the wheels. Lowering the back a little would certainly raise that front lip a touch, hmm, interesting!
    Adam
    Previously -
    2002 Bora V5
