hey james,
might have some trouble finding someone here that has knowledge of this model.what area are you from?? have you got any good mechs your way??
Hey guys,
wondering if someone can assist with problems i'm experiencing in my Bora V5.
Basically on very light acceleration i'm hearing a pinging/ticking noise coming from the engine- obviously i can only hear this on quiet streets at night when there is no noise at all. It is also occuring on low acceleration when the engine is under load- i.e. going up inclines etc.
I'm also noticing the auto gear changes are becoming "not as smooth" as they should. for e.g. sometimes it may go in a higher gear when not necesary, causing the car to become sluggish. sometimes when changing into 2nd/3rd its a very noticable transition, and the car lunges slightly. There is no odd or strange noises coming from the gearbox also.
If anyone can assist it would be greatly appreciated.
James.
hey james,
Got to be an ECU scan to start off with. No point in guessing when there is a good chance that the ECU can shed some light on the problem.
I would consider trying higher octane petrol too, next time you fill up.
Something else to consider would be the MAF, airflow meter. It could be that it isn't measuring airflow correctly, there are a common failure item but don't throw ECU codes usually. You can see the airflow with VAG-COM.
does it sound like plastics knocking? or door trims etc.?
I'm driving a V5 as well and I've go those sounds from the dash or engine bay I dunno
Could be worth using BP Ultimate for a tank or two and seeing if it makes any difference (To the engine noises, not the transmission :p)
Had the same tranny problem on my wifes V5 .. it was a warenty job.. something to do with a fuse or ecu .. it wasn't a big deal to get fixed
