I would get it topped up ASAP then closely monitor it for the next week in case it drops again.
Also check the coolant sensor, the original black sensors are known to be faulty which in turn leads them to always read mid-point regardless of the actual temp, I think that was the symptom. Anyway, it should be replaced with a newer green sensor if you still have the black.
Good luck!
Adam
