Haha sounds exactly like my car at the moment. Dropped a cylinder i think and is running quite bad, taking it into service soon. I think it could be injectors or as you said the coil pack not sure will let you know on mine. As for the oxygen sensors (also bad on mine) There are four in a bora, 2 post cat and 2 pre cat. I'f you find out that you have one buggered i ordered the wrong oxygen sensor and got the post cat sensor instead of pre cat so if you need that i have one. The oxygen sensor wont cause it to run rough it will however effect your fuel consumption as the engine uses it to determine how much oxygen there is left in the exhaust and adjusts the fuel ratio according to that. good luck and have fun
EDIT: Try ecs tuning nice and cheap. Also to replace an oxygen sensor its just remove the old one (With loads of pain and agony) And plug in new one nothing really to go wrong.
