MAF, o2 sensor?
Is the temperature gauge right on 90oC?
Might wanna put up what engine too (i cant remeber... 2lt?)
Having a slight issue with my girl friend's Bora.
Its not constant but usually happens with a lot of stop start driving like city or traffic.
The idle stays at about 800-900rpm but the engine shakes and it feels like a v8 with a big cam. The exhaust note is a very noticeable 'putt putt' and it also smells like egg farts. We checked the leads, coil, plugs to see if its running on 3 cylinders but its not and we filled it up with 98ron. It goes away after a bit of normal open road driving.
Anyone had a similar issue or can shed some light on this?
A search didn't turn up much but the closest i got was faulty MAF.
MK1 GLS 3door
A4 B7 2.0T
MAF, o2 sensor?
Sorry its a 2l 8v.
Without an engine light on will a Vagcom pick it up?
MK1 GLS 3door
A4 B7 2.0T
I'd wager a vacuum leak. In start stop its loosing its vacuum in the brakes and reservoir and thus ****ty idle. Have a listen for a hissing sound if you can.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
I reckon vacuum leak too, take the cover off and look at all the plastic brether hoses around the engine. I bet one or more has a split and is loosing vacuum and oil.
Cheers guys ill check it out.
MK1 GLS 3door
A4 B7 2.0T
