Results 1 to 7 of 7
Thread: Bora rough idle
    Feb 2007
    Bora rough idle
    Having a slight issue with my girl friend's Bora.
    Its not constant but usually happens with a lot of stop start driving like city or traffic.
    The idle stays at about 800-900rpm but the engine shakes and it feels like a v8 with a big cam. The exhaust note is a very noticeable 'putt putt' and it also smells like egg farts. We checked the leads, coil, plugs to see if its running on 3 cylinders but its not and we filled it up with 98ron. It goes away after a bit of normal open road driving.
    Anyone had a similar issue or can shed some light on this?
    A search didn't turn up much but the closest i got was faulty MAF.
    MK1 GLS 3door
    A4 B7 2.0T
    MAF, o2 sensor?
    Is the temperature gauge right on 90oC?
    Might wanna put up what engine too (i cant remeber... 2lt?)
    Feb 2007
    Sorry its a 2l 8v.
    Without an engine light on will a Vagcom pick it up?
    MK1 GLS 3door
    A4 B7 2.0T
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by Spyda View Post
    I'm thinking it should, but I'll defer to others with greater experience in this area ... When Gavin scanned my car he was able to show me coolant temperatures, voltages and all manner of things ... it's pretty specific.
    Mar 2010
    Lesmurdie
    I'd wager a vacuum leak. In start stop its loosing its vacuum in the brakes and reservoir and thus ****ty idle. Have a listen for a hissing sound if you can.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Camden, Sydney
    I reckon vacuum leak too, take the cover off and look at all the plastic brether hoses around the engine. I bet one or more has a split and is loosing vacuum and oil.
    Feb 2007
    Cheers guys ill check it out.
    MK1 GLS 3door
    A4 B7 2.0T
