Onto day 4 of this madness, unfortunately due to the cold weather the paint was not touch dry until the next day.
removed all the masking tape, regreased all the slide pins.
Then it was install time.
New dust shields, new bolts, screws, rotors, pads, fluids.
Before
After
Rears before
After
Side note: My old OE pads had the wear sensor and the new Brembo's did not.
So to remove the stupid brake pad wear sensor warning from the cluster I coded it out using VCDS.
Flushed all the lines (used the old "2 person" method"). Cycled the ABS pump using VCDS just to be sure. Done!
