Bora knuckles V R32 knuckles.
Note the R32 position of the ball joint sits lower. This helps bring the driveshafts closer to parallel when the vehicle is lowered.
And the Bora arms V R32 arms.
Note the tapered end of the arm allows for wider track and more camber adjustment.
I was all over the place trying to get this done in one day so i may have missed a few steps here but they would've been covered previously when I installed the front struts.
First step was to undo the inner CV joint whilst the knuckle and brake caliper were still attached. I didn't get a pic of it but I normally take a small flat head screw driver (marked in red) and slip it between the brake caliper and the carrier and into one of the disc vents. This stops the wheel from turning whilst undoing the inner CV joint.
6x M10 triple square. Torqued to 70nM.
Removed the knuckle
Removing the control arm was fairly straight forward, 18mm bolt / nut at the rear (70nM +90')
and 1 at the front (also 70nM + 90').
Problem with the front one was it kept hitting the sump before I could fully extract it.
So I was forced to lower the whole subframe to get the clearance needed and pull the arms out.
Tie Rods.
On standard Golfs / Bora the tie rod ends face downwards and angle towards the rear of the vehicle.
When installing R32 knuckles it's necessary to flip them upside down - THEN swap them left to right so they angle towards the rear. Note the angle changes when flipped upside down.
