haha dude if I'd known that earlier! I had to play musical bulbs for a while there not realizing I needed the colored ones.
Interesting about the fogs, not sure why from factory only one would work, should have checked if both sides worked on the factory tails I guess. I'll jump on UKMKIV's and see I can get any info on that because it's going to bug me that only one works.
RE: Carpet. Old MK4 vet like you will smash it out in no time. There was only 2 things that really stumped me a little.
Removing the bonnet release handle (there's a small retaining clip you need to pull out) and this section of the carpet here.
You have 2 options, cut a slit in the carpet at this location (Like I did)
Or undo the support bracket for the dash, plus remove the interconnecting ac/heater duct
That allows you to pull the carpet towards the back and out. I might throw up some steps when it comes time to putting it all in.
