Page 7 of 16 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 155
Thread: Bora R32 Build Thread
  1. #61
    Apr 2014
    Penrith, NSW
    Got busy on the weekend swapping over panels, rad support, fan assembly etc just to test fit everything. Still needs adjustment but it's the first time the beast has looked like a car and not a wreck in over a year!
    Donor vehicle
    Bora R32 Build Thread-img_9256-jpg
    Bora R32 Build Thread-img_9263-jpg
    Project car
    Bora R32 Build Thread-img_9257-jpg
    Bora R32 Build Thread-img_9258-jpg
    This took WAY longer than it looks. Good 1.5days.
  2. #62
    Looking good. All the new panels in good condition or still need work?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #63
    Apr 2014
    Penrith, NSW
    Panels are straight, just need paint. Not looking forward to unpicking the bump strip from the bar cover though
  4. #64
    Apr 2014
    Penrith, NSW
    REPAIRING THE DAMAGE
    Replacing airbags, crash sensors, seat belts and airbag module.
    Many busy weekends spent doing this right and as per spec and a few things had to be done that I wasn't expecting unfortunately. Everything done here is as per VW spec. If it said "replace it" it got replaced regardless.
    As per VW. If your front airbags deploy you must replace following.
    Airbags (der!)
    Front Crash Sensors (located under front seats)
    Airbag Module (some say it can be cleared, but why risk it)
    Passenger Front Airbag Mounts
    Drivers Clock Spring
    Seat belts (if deployed)
    So here we go.
    Started by replacing the seat belts. Firstly, you'll need to remove your front seats.
    Remove Lower Pillar Cover (note tension on seatbelt, deployed and needs to be replaced)
    Bora R32 Build Thread-img_9388-jpg
    Lift plastic cover undo top bolt. (For installation, torque this bolt to 40nM)
    Bora R32 Build Thread-img_9389-jpg
    Pry off Upper Pillar Cover and unscrew belt retainer
    Bora R32 Build Thread-img_9400-jpg
    Lift up rear seat and unscrew sill trim, lift up C pillar trim enough to release sill trim.
    Bora R32 Build Thread-img_9391-jpg
    Unscrew lower sill trim screws
    Bora R32 Build Thread-img_9394-jpg
    Begin prying off sill trim. I found it easier to start from the rear and work my way forward. You will also need to lift the small trim on the A pillar to release the sill trim.
    Bora R32 Build Thread-img_9392-jpg
    Disconnect seatbelt igniter.
    Bora R32 Build Thread-img_9395-jpg
    Lift carpet and insulation and remove lower bolt (installation, torque 40nM)
    Bora R32 Build Thread-img_9402-jpg
    Remove seatbelt bolt here (torque 40nM) lift belt up and out of retainer.
    Bora R32 Build Thread-img_9403-jpg
    And you should be left with this.
    Bora R32 Build Thread-untitled-jpg
    Installation is the reverse order.
  5. #65
    Apr 2014
    Penrith, NSW
    Next.... whilst the seats are out time to replace the crash sensor.
    With front seats removed. Lift carpet and insulation, disconnect crash sensor and unscrew 3x Hex screws.
    Bora R32 Build Thread-img_9408-jpg
    Replace old for new (old on the right as I scratch the sticker as not to get confused!). They can only be installed in one direction as locating pin prevents any other way.
    Bora R32 Build Thread-img_9411-jpg
  6. #66
    Apr 2014
    Penrith, NSW
    Now onto Airbag Module which is located towards the firewall under radio.
    Remove shifter and boot, push centre of boot forward and lift up.
    Bora R32 Build Thread-img_9459-jpg
    Lift out ashtray and unscrew hidden torq screw.
    Unscrew centre console trim (passenger and drivers sides)
    Bora R32 Build Thread-img_9461-jpg
    Bora R32 Build Thread-img_9462-jpg
    Lift the centre console up starting near shifter boot and pull up and back. The airbag module should now be visible.
    Bora R32 Build Thread-img_9472-jpg
    Unscrew 3x 10mm nuts and disconnect yellow connector.
    Bora R32 Build Thread-img_9473-jpg
    Old and New
    Bora R32 Build Thread-img_9548-jpg
    Installation reverse.
  7. #67
    Apr 2014
    Penrith, NSW
    Next onto the drivers airbag.
    Rotate steering wheel 90 degrees to expose access hole at rear.
    Bora R32 Build Thread-img_9494-jpg
    Bora R32 Build Thread-img_9496-jpg
    With a flat screwdriver insert and push front screw driver downwards. This will release the springs holding in the airbag and it should just pop off.
    Sometimes they're easy. Sometimes they're a mother@&%^er to remove, be patient.
    Bora R32 Build Thread-img_9498-jpg
    Pull off yellow connector, lift airbag out.
  8. #68
    Apr 2014
    Penrith, NSW
    Replacing Clock spring
    Remove steering wheel nut. (installation, torque to 55nM)
    Bora R32 Build Thread-img_9499-jpg
    Steering wheel will now pull off. Before removing though make sure your wheels are straight! Mark wheel and steering column to ensure they all line up when reinstalling. I didn't do this because I'm installing the R32 wheel
    remove steering wheel cover trim upper and lower
    Bora R32 Build Thread-img_9500-jpg
    Bora R32 Build Thread-img_9501-jpg
    This will expose the clock spring. Disconnect yellow plug.
    Bora R32 Build Thread-img_9502-jpg
    Pry off clock spring.
    Bora R32 Build Thread-img_9503-jpg
    If you're reusing it for whatever reason, cable tie to ensure it does not spin freely as the steering angle sensor is part of the clock spring. New and old
    Bora R32 Build Thread-img_9549-jpg
    Installation is reverse.
  9. #69
    Apr 2014
    Penrith, NSW
    Replacing passenger airbag.
    Unscrew airbag dash cover
    Bora R32 Build Thread-img_9422-jpg
    Unscrew airbag 2x each side.
    Bora R32 Build Thread-img_9417-jpg
    Bora R32 Build Thread-img_9418-jpg
    Slide airbag connector out of retainer and disconnect.
    Bora R32 Build Thread-img_9481-jpg
    Old and new
    Bora R32 Build Thread-img_9421-jpg
    Unscrew airbag brackets both sides and replace (2.5nM for installation) note the coloured indicators which show they deformed from airbag deployment (it's an explosion after all!).
    Bora R32 Build Thread-img_9424-jpg
    Bora R32 Build Thread-img_9423-jpg
    Bora R32 Build Thread-img_9425-jpg
    Bora R32 Build Thread-img_9428-jpg
    Installation is reverse. The airbag dash cover is simply pushed back into place.
  10. #70
    Apr 2014
    Penrith, NSW
    If this was a straight up repair, the only thing left to do would be to recode the new airbag module. I'll put steps on that when the time comes.
    Unfortunately for me, when I went to put the airbag dash pad back in, it just wouldn't sit right.
    Bora R32 Build Thread-img_9544-jpg
    Little did I notice when the airbag deployed it completely cracked the underside of the dash. Doesn't look like much from here.
    Bora R32 Build Thread-img_9453-jpg
    But it meant the whole dash had to be replaced
