Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 155
Thread: Bora R32 Build Thread
  1. #41
    Apr 2014
    Penrith, NSW
    Ah but what is my "current data"? If I swap the ECU and Cluster, wouldn't it be easier to just do the barrell and ignition module as well?
    How'd you go with your swap Ian? Did you swap the ECU as well?
  2. #42
    May 2015
    I just thought getting to the barrell was difficult and then switching it is a delicate task?
    I’ve swappwd the ECU (me7.5 > 7.1.1), harness and engine. Everything coded to match. Works a treat.
  3. #43
    Apr 2014
    Penrith, NSW
    Progress has been slow over the past months but FINALLY ready to pull the donk out. Images are mainly for my own reference for later on when I go to humpty dumpty this thing back together.
    Step 1. Get the front off, CHECK! Accident took care of that.
    Bora R32 Build Thread-img_8267-jpg
    Many hours later mucking around trying to work out how to jack it up safely, a hazard of living on hill and doing this on the grass. As you can see the drop across a 1-1.5m is a good 50mm... It was pretty sketchy at time.
    Bora R32 Build Thread-img_8248-jpg
    Started assessing the damage. Few little things broken but nothing major.
    Bora R32 Build Thread-img_7975-jpg
    Bracket for air pump, air pump was cracked at the mounting point as well.
    Bora R32 Build Thread-img_7976-jpg
    Oil cooler, dented
    Bora R32 Build Thread-img_7977-jpg
    hi/low A/C compressor lines were completely busted up. Which saved me from degassing the system a small win.
    Bora R32 Build Thread-img_7872-jpg
  4. #44
    Apr 2014
    Penrith, NSW
    Started disconnecting all the coolant lines.
    Bora R32 Build Thread-img_8035-jpg
    thermo housing
    Bora R32 Build Thread-img_8261-jpg
    Bora R32 Build Thread-img_7982-jpg
    return lines at the rear of engine, on both sides.
    Bora R32 Build Thread-img_78721-jpg
    And this little bugger for the secondary coolant pump.
  5. #45
    Apr 2014
    Penrith, NSW
    Fuel lines, disconnected and sealed.
    Bora R32 Build Thread-img_8255-jpg
    unbolted downpipes.
    Bora R32 Build Thread-img_8260-jpg
    cable ends for the gear selectors and speedo sensor.
    Bora R32 Build Thread-img_7980-jpg
    Bora R32 Build Thread-img_7981-jpg
    clamped and disconnect clutch bleeder assembly
    Bora R32 Build Thread-img_82531-jpg
  6. #46
    Apr 2014
    Penrith, NSW
    driveshafts out
    Bora R32 Build Thread-img_7871-jpg
    unbolted propshaft. Massive PITA, access is just insanely small.
    Bora R32 Build Thread-img_8247-jpg
    removed dogbone mount
    Bora R32 Build Thread-img_8088-jpg
    cowl panel, the wiper arms were an absolute motherf^#%er to remove.
    Bora R32 Build Thread-img_8251-jpg
    ECU out
    Bora R32 Build Thread-img_8252-jpg
  7. #47
    Apr 2014
    Penrith, NSW
    Bagged and tagged the lot.
    Bora R32 Build Thread-img_8266-jpg
    And lastly. Decided to put the bar rio up to take a better look at the impact on the rails.
    Bora R32 Build Thread-img_8263-jpg
    RH rail is out but it's nothing major, just looks bad from this angle because the mounting plate is all bent up. But the LH could be out a little as well although I couldn't see damage to it, the bar rio should sit flush.. And because of the angle of impact it is possible it's pushed both rails across a couple of mils.
    Bora R32 Build Thread-img_8262-jpg
    Pickup a hoist over the long weekend, next strap it and yank that bugger out. Then off to the repair to square this all up.
  8. #48
    Apr 2014
    Penrith, NSW
    And sadly this is how I've been moving it around my yard for the past couple of months. One smashed MK4 towing another....
    Bora R32 Build Thread-img_77371-jpg
  9. #49
    Mar 2017
    I had to use penetrating oil on my wiper bolts to get them off the first time, such a pain.
    Edit: you might have experienced this already, but be careful with the cowl off, I had mine off for about a week outside, dust and a couple leaves got in the channel it clips into and I had to clean it all up before the cowl would press back in.
  10. #50
    Apr 2014
    Penrith, NSW
    Quote Originally Posted by jmcc View Post
    She's outside exposed to the elements, cowl panel went straight back on as soon as I got the ECU out and pulled the engine harness through
