Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 155
Thread: Bora R32 Build Thread
  1. #71
    Apr 2014
    Penrith, NSW
    Pulled the dash out of the R32 (identical to the Bora dash, same part no.)
    Bora R32 Build Thread-img_9456-jpg
    Bora R32 Build Thread-img_9457-jpg
    Bora dash, note huge crack from airbag.
    Bora R32 Build Thread-img_9545-jpg
    R32 dash, schmick!
    Bora R32 Build Thread-img_9546-jpg
    Epic job.
  2. #72
    Thanks for sharing but glad it was you doing all this not me.
  3. #73
    Apr 2014
    Penrith, NSW
    Here's how it sits now. Everything replaced, wired up and good to go!
    Bora R32 Build Thread-img_9634-jpg
    Bora R32 Build Thread-img_9625-jpg
  4. #74
    Mar 2017
    wow, good as new, looks clean, nice!
    2002 Golf GTI - K03S | 3" Downpipe | 312mm DBA T3 Slotted with Forza Pads | | Forge 008 | Forge Hoses | ECS Performance Mounts | R32 and Urethane Bushings | Pipercross Filter | Sachs VR6 Clutch with 14lb Balanced Flywheel
  5. #75
    Apr 2014
    Penrith, NSW
    Well here we go again....
    After a few weekend's on the tools and a brief game of "musical MK4's" the R32 engine is finally out!
    Bora R32 Build Thread-img_0052-jpg
    Bora R32 Build Thread-img_0053-jpg
    Bora R32 Build Thread-img_0055-jpg
    All the steps involved mentioned in prior pages for removing the BDE engine were identical for the R32. With the exception of these 2 items.
    Vaccuum Line for Exhaust Flapper
    Bora R32 Build Thread-img_9950-jpg
    AND, the Secondary Radiator
    Bora R32 Build Thread-img_9902-jpg
    Undecided what to do with both at the moment but that's a problem for another day.
    Whilst the R32 engine is out I'll be doing chains/guide and clutch. So I'll start stripping the engine down over the next couple of weeks.
  6. #76
    May 2015
    Moving on nicely with things there Mr B!
  7. #77
    Apr 2014
    Penrith, NSW
    Engine is getting stripped down, ready for clutch, chains and guides.
    Bora R32 Build Thread-img_0243-jpg
    Definitely in need of a new clutch! This was it at about 150,000kms.
    Bora R32 Build Thread-img_0244-jpg
    Whilst I wait for those bits to arrive thought I'd turn my attention to something that was bugging me. Apparently the previous owner or their mechanic had no idea how VAG electrical connectors work . 4/6 coil plug were completely destroyed along with one injector plug. So it was swap them out
    Bora R32 Build Thread-img_0264-jpg
    So I grabbed the loom from the BDE Engine armed with my eBay tools and got to work.
    Bora R32 Build Thread-img_0276-jpg
    Replacing Coil connector (P/N 1J0973724)
    Slide the purple retainer to the side
    Bora R32 Build Thread-img_0266-jpg
    Remove the connector cover
    Bora R32 Build Thread-img_0265-jpg
    Insert ebay Tool (3mm) into top and bottom and push down till it clicks.
    Bora R32 Build Thread-img_0267-jpg
    Pull out terminal wire from the back.
    Bora R32 Build Thread-img_0268-jpg
    Repeat x4.. LH R32 connector (the terminal block actually snapped off this connector. Not sure if it was just brittle or I wiggled the terminal tool and snapped it meh..), RH Bora BDE V6 connector. Same p/n though. Installation in reverse.
    Bora R32 Build Thread-img_0269-jpg
    Next time to replace the injector plug (P/N 06A973722)
    Lift the purple retainer up and out.
    Bora R32 Build Thread-img_0270-jpg
    This one was a little tricky to get a pic of but there is a small black clip on the inside which needs to be pryed up.
    Bora R32 Build Thread-img_0275-jpg
    Then just pull it out from the back. Installation in reverse.
    Bora R32 Build Thread-img_0271-jpg
    Attached Thumbnails Attached Thumbnails Bora R32 Build Thread-img_0275-jpg
  8. #78
    Apr 2014
    Penrith, NSW
    * REMOVING THE SUBFRAME, SUSPENSION, P/S RACK, SWAY BAR - R32*
    Back to it over the weekend.
    First step, disconnect the steering column from the rack.
    Remove the deadpedal
    Bora R32 Build Thread-img_0487-jpg
    Unbolt 13mm bolt from steering column universal joint
    Bora R32 Build Thread-img_0488-jpg
    Remove headlight level sensor from chassis
    Bora R32 Build Thread-img_0489-jpg
    Bora R32 Build Thread-img_0490-jpg
    Now onto the Brakes, these are eventually going on the Bora.
    Disconnect brake pad wear sensor
    Bora R32 Build Thread-img_0491-jpg
    disconnect ABS sensor
    Bora R32 Build Thread-img_0493-jpg
    Pull away ABS sensor wiring away from strut.
    Bora R32 Build Thread-img_0495-jpg
    Bora R32 Build Thread-img_0496-jpg
    Remove brake line plastic shield and line clamp and remove from strut. Remove 2x 19mm brake carrier bolts and wire tie brake assembly to body of the vehicle.
    Bora R32 Build Thread-img_0494-jpg
    Bora R32 Build Thread-img_0497-jpg
    Undo 2x 21mm strut nuts (impact required or strut socket)
    Bora R32 Build Thread-img_0498-jpg
    Not necessary but as I was doing it solo i used some elastic straps to tie up the struts so they wouldn't just fall forward when lowering the subframe.
    Bora R32 Build Thread-img_0499-jpg
    Undo 4x subframe bolts (24mm from memory and they are TTY, replace with new according to VW)
    Bora R32 Build Thread-img_0501-jpg
    Bora R32 Build Thread-img_0502-jpg
    Lastly, 2x 13mm O2 sensor wiring shield at the rear of the subframe
    Bora R32 Build Thread-img_0506-jpg
    Then all that's left is to lower that bad boy down.
    Bora R32 Build Thread-img_0500-jpg
    Bora R32 Build Thread-img_0510-jpg
    DONE! I'll give it a clean up then bolt it up to the Bora.
  9. #79
    May 2015
    woop woop - nice progress!
  10. #80
    Apr 2014
    Penrith, NSW
    Pulled the .:R subframe out on the weekend gave it a quick clean up before the install and got it all fitted up. Will need to replace the bolts at some stage as they're one-time use and get torque'd to 100nm +90
    Bora R32 Build Thread-img_0649-jpg
    Struts to body were 60nM
    Bora R32 Build Thread-img_0671-jpg
    Also got around to fitting the front brakes as part of that, they'll need new fluid but that's a little hard to do with being able to cycle the ABS pump. Found that I had to swap out the front brake lines to match the R32 calipers, they were slightly different between the 4motion and R32. Lastly carriers to hub were 125nM (little loctite if they look worse for wear).
    Bora R32 Build Thread-img_0653-jpg
    different in 4motion (right) brake lines V R32 (left)
    Bora R32 Build Thread-img_0655-jpg
    Bora R32 Build Thread-img_0672-jpg
    Bora R32 Build Thread-img_0673-jpg
    Next up, rear shocks and springs!
