Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Bora - Oil Pressure Warning
    syncro Guest
    Your dynamic oil pressure switch is either defective or the wrong one.
    Nine out of ten mechanics fit the wrong one.
    By clocks I meant the instrument cluster, which seems to be common on mk4s like it was on mk2s.....
    pursuit_ute Guest
    Ok, got it Gavin, that seems to run true with the chance of a poor contact on the back of the cluster then.
    Syncro - I have been told there are two switches, when you said that installing the wrong switch was common, do you mean that the high or low is being installed in the wrong location or just plain wrong switches all together?
    There is a low pressure switch that turns the oil light off when you start the car. The other is a high pressure one which, if the pressure isn't high enough above 2000 revs, sets the buzzer off.
    You could get the switches in the wrong place and never get a warning or get a constant warning.
    Apr 2006
    VW Race HQ - Sydney
    Has this been solved yet ?
    Ive had 1 problem like this before on a Bora .
    make sure the engine block has a good earth .
    Then you need to trace the wire from the switch back into the instrument cluster . If its the cluster itself it generally wont have 1 problem as the earth points are shared . The wire is a single wire , I think it changes colour at the junction point in the plenum chamber .
    Good luck
    Seb
    Apr 2006
    Hobart,Tas
    I would always use German filters on a VW. We did a test on a kombi years back and found the Ryco ones dropped the pressure by 8 lbs!
    Genuine, Hengst or Mann filters only. Leave the Rycos for the backyarders!!
    Camden, Sydney
    I reckon someone has fitted the wrong oil pressure switch. There are several different ones and mechanics always get the wrong ones.
    Tell us the colours of the two that are on your car and we will try and confirm this.
    Jul 2005
    Only one oil pressure switch on a 24v vr6- black one- 1.4 bar.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    syncro Guest
    Quote Originally Posted by aprr32
    Must be the only modern VAG car that does.
    Camden, Sydney
    Yeah the earlier VR6 engines have 2.
Similar Threads
  1. VW bora V6 4motion - engine problem
    By sim2002 in forum Mk4 Golf & Bora and New Beetle
    Last Post: 14-11-2011, 08:00 PM
  2. V6 Bora that needs to go faster
    By Mr BetterDeal in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 06-10-2007, 01:46 PM
  3. Wiper resevoir... no warning?
    By fergVdub in forum Mk5 Golf & Jetta
    Last Post: 02-04-2007, 05:10 PM
  4. gti boost pressure??
    By gpk_gti in forum Mk4 Golf & Bora and New Beetle
    Last Post: 04-03-2007, 08:02 PM
  5. Bora V6 Coolant Temperature Sender Location
    By miles in forum Mk3 Golf & Vento
    Last Post: 25-02-2006, 11:42 AM
