If you've already replaced the oil and filter in it, try bedding the clutch plates in again.
Find some open space on a sealed surface, and do some low-speed figure 8s, whilst accelerating through the turns.
Hi guys great info on this forum ,
it it looks like I have a fault with the haldex on my mk4 bora , it's had a recent service .
if I remove the fuse #31 the rear disengages and I can reverse out of parking easily for eg .
What are my options to get this repaired these days ?
Regards , Neal
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Thank you , I'll give that a try . I'm not sure if the problem was there before the Haldex was serviced or not as I've only recently bought the car and found the problem after the cash was handed over .
Who did the service ?
My local European car experts put the first lot of Haldex fluid into the rear diff ....
I'm not sure as it was done before I bought the car recently
