Bora Grill?
Does anyone know anything about theses lower grills?
I have only seen them on a couple of bora. Anyone know part numbers or how much they are, or do i just ring up vw spare parts and quiz them?
http://www.vwwatercooled.org.au/newf...1&d=1228211283
Not sure if you're referring to the front bar or the nose grill where the VW badge is.
I believe the nose piece is or is similar to the Oettinger grill?
http://www.oettinger.com.au/2861.jpg
http://www.oettinger.com.au/oau_vwjetta-bora4_bs.html
Harding performance (Guy_H on here) is the official importer for there gear here in Australia.
Hope this helps.
Cheers,
Trent
Sorry i should of explained it a bit better. I actually mean the 3 lower black inserts with mesh on the back of them.
i'm missing one of those... every time my car gets caught on a curb they seem to pop out. I stopped replacing them, out of shear laziness. Unfortunately i don't think they are an OEM part, AFAIK all bora's and golfs came with the slats.
Here is a write-up on how to make your own mesh ones though: http://forums.vwvortex.com/zerothread?id=396289
Best of luck if you do go this route, would look really nice,
Phil
Thanks heaps I'll look into it
- You may not post replies
- You may not edit your posts
Forum Rules
